Red Lion Help
lcanada
Nov 2017
Arkansas
18
Hey guys,
I was wondering if a G303 Red Lion HMI can be used as a scanner?
I am having trouble finding information on this.
You need to be more specific. The term "scanner" can have many meanings. I assume you mean some type of communication master? Which fieldbus?
My apologies. I have an M10-iA robot with an R30iA controller. I ordered it with the ethernet adapter option but not the scanner option. I am trying to use ethernet to send and recieve IO signals. I realize that i could use an Allen Bradley PLC to accomplish this but I would prefer to not order one if I can do it with a Red Lion, as we have several of these around our facility. Hope this is more clear.
Red Lion G30x devices do have an EtherNet/IP Adapter driver, but they don't have a "Scanner" driver.
Your best bet is going to be to refit that robot controller with the EtherNet/IP scanner, so that it can control I/O (and the G306) in the way you intend.
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,125
I'm working on a Graphite that is continuously looping through the start up sequence then stops and shows a page that says "system could not...
4,929
When you are compiling (translating in Red Lion parlance) user defined programs - what does "Unexpected End-of-Text" error mean? It is at the END...
1,800
Hello everyone, Brian the Newb here again regarding Crimson 3.0 and J1939 CAN protocols. I had searched the archives and I DID find a couple of...
2,999
I have a cardboard baler that uses the Red Lion CL05 interface to control bale size, wire twists and a couple other things. It is showing invalid...
2,816
