RDM Instruction in Omron S6
mmoorhouse
Guest
M
Does anyone have info on the RDM instruction in an Omron S6 PLC. We need to make some changes but don't know how this inst works. If anyone can email a manual it would also help as we have drawn a blank with Omron. Thanks Malcolm Moorhouse [email protected]
The RDM instruction is a classic drum sequencer with 32 presets. I will email you the entire manual. For those who are interested, here are excerpts from the S6 manual:
Simatic S7-300 6ES7-315-1AF02-0AB0 With Berger Lahr Sig positec WDM3-004.1801 & VRDM Hello to all. I have read these forums for awhile and they...
1,975
I'm trying to dig to the source of a minor "recoverable" system fault throwing a fault light on a machine that has been confusing my operator...
81
91
Does this instruction calculate values during a single scan, or does it require number of scans based on element count in the array? For Example...
115
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
263
