Lost comm w/ Phoenix Ethernet/IP Bus Coupler (IL EIP BK DI8 DO4 2TX-PAC)
phuz
Jun 2008
Mohnton, PA
1,044
I re-did a machine for a customer, which had Yaskawa MP2300Siec w/ 5-axis and Phoenix Contact Ethernet/IP I/O. According to the drawing and the PLC program, the bus coupler was 192.168.1.10. While the machine was being refurb'd, it sat powered off for about a month. I am now trying to set it up to communicate with Allen Bradley hardware, but I can't even ping the bus coupler. I wouldn't think that this would lose its memory after a month. I did load BOOTP but didn't see the bus coupler on there, so I don't believe it to have reverted to factory settings. I am afraid to perform a reset on it because I don't know what settings are stored in there.
This is my first time using Phoenix I/O. Any help appreciated.
You may already have the documentaion, but if not, go here:
https://www.phoenixcontact.com/online/portal/us?uri=pxc-oc-itemdetail:pid=2897758&library=usen&tab=1
Below the description are tabs with categories of info. Click the right arrow to reveal Downloads and find the manuals and Applications Notes. One of the tehcnotes is aimed at connecting to Compactlogix and has info about BootP.
The manual titled "um_en_il_eip_bk_di8_do4_2tx_pac_7538_en_03" appears to have information about using the reset button to default the configuration.
If you press the reset button during power up, the device should return to default IP settings and enable bootP.
Thanks, yup I have it.
I'm aware of the reset, but not sure I'm quite ready to do this. I'm concerned why, after a month, it would suddenly not respond on the IP it was originally set.
Hello Everyone! I'm in trouble here... We have two PLCs on a network IP (192.168.1.43 node 51, 192.168.1.44 node 52). I used the file and program...
18
7,846
trying to force an input to test a machine input was already with 24vdc and jumpered it to 0v, and shorted out joined 24vdc positive and 0v common...
2,575
hi everyone, I have a problem, it seems that in somewhere on the programming the reference tends to lost mabye one time at day. I write this...
81
Well, not sure what else we can do with this one at the moment. Will chat with Rockwell in the morning but am not expecting much. Guess I'm...
1,124
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
1,010
