schwarz633
I'm considering the use of some Scaime eNod4-D ETH controllers for a filler application. It is EtherNet/IP compatible and they do provide an EDS. I'm having a problem getting the resultant tag structure to correlate to the documentation provided.
I've loaded the EDS into my Rockwell Logix5000 and was able to create a eNod4-D ethernet device named FillHead1A in my test program. It created the following tags:
From eNod4D
1. FillHead1A:I.ConnectionFaulted
2. FillHead1A:I.RunMode
3. FillHead1A:I.Data
Tags 1 & 2 are single bit boolean (BOOL). Tag 3 is a 72 element array of 16 bit words (SINT).
To eNod4D
1. FillHead1A:O.Data
Tag 1 is a 2 element array of 16 bit words (SINT).
The US distributor doesn't seem to offer much in the way of technical support and I really don't want to rely on technical support from France.
Has anybody ever used this device with a Logix controller?
From eNod4D
To eNod4D
