Automate40 comms with RSlinx
tkdwa
Sep 2004
Would any one know if it is possible to communicate with Automate40(yes they are still alive) with RSlinx or any other windows program We currently use APX via Dos but with more and more programs on windows the dos days are nearly over(sweet memories)
We can not afford to replace all of our Automates and hey still do a great job but fault finding in the program is tirersome.
Mark P (the old guys)
Seven years ago I was told that I was responsible for support of AutoMate and Shark PLC's in five states. I've had one phone call since, so they must be running fine !
No, there are no Windows tools or drivers for the AutoMate (that I know about). Keep dusting off old DOS PCs.
Have an A40 that keeps droping out of run, have to go on-line with it(APS) to put it back in run. Do I need to capture error codes to see whats...
1,954
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
130
Hello, can someone share/explain How to check comms between PC and PLC via TeamViewer? TIA
420
Has anyone setup communications with Red Lion 3.0 MODBUS to Baker Hughes Centrilift GCS VFD? Thanks
97
Hi , Looking for some help. We have a 343-1 PN Lean Card & 315-2DP connected to an external system collecting data. After a recent shutdown...
73
