S7- 1200 analog scaling
an interesting question. I too was looking for it
I've never seen an HMI automatically shift an INT into a decimal. Is this common? I use reals whenever I need decimals.
For what I mean, There’s usually a format section of the value display or it's done in scaling tag. I don’t really have evidence of ALL hmi but all I’ve worked with. It is not the same as fixed decimals to use a 10 time bigger int in code. I too use reals for convenience most of the time, but that’s only because the platforms don’t suffer from the computational need or the double data size of the value.
have a look at the images - for the S7 300/400 range - My GTD 3 is older so does not have S7 1200 range but should be similar.
It was successful. Using datablock addressing is a lot easier and works perfect for what I need to do: to display temperature readings in Mitsubishi got2000 through s7-1200 cpu. Thanks a lot.
Many thanks also for all the other ideas.
I have a 4-20mA level input that needs to be controlled (PID). But the level transmitter is configured such way that 4mA correspond to 100%(full)...
3,937
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
681
Pretty simple question, but I was wondering how I can set the Analog Output 1 of an S7-1200 (DC/DC/Relay) to be proportional to a data tag. I...
855
Guys, i need your help.. Im using S7-1200 CPU1212c AC/DC/RLY and for my project, i want to learn how to program this in analog inputs.. Im using...
2,460
hi I have s7 1200 analog input module 4-20MA , I need a help to scale the temperature from the transducer that measure 0- 100°C to the hmi...
2,962
