What is the difference between a 1756-L62 A and a 1756-L62 B ?
Cydog
Feb 2018
Maryland
313
Good Evening ,
Could you folks tell me what the difference is between a 1756-L62 A and a 1756-L62 B ? I found a 1756-L62 A , but all the CPU's that I have in operation are B's . Is there any major differences ?
Thanks so much ,
They are physically slightly different; the CF card slot was moved from the bottom to the front, the serial port is in a different location, and they use slightly different RAM backup batteries.
But logically they are identical; Series A and Series B controllers will all run the same firmware, and you cannot tell them apart in software.
From the Rockwell KB:
1756-L6x Controllers: Difference between Series A vs. Series B
43312 | Date Created: 09/18/2007 | Last Updated: 01/11/2018
Access Level: TechConnect Email this page Print Subscribe to Updates
Question
What are the differences between a Series A and Series B ControlLogix L61, L62 or L63 Controller?
Environment
1756-L61
1756-L62
1756-L63
1756-L64
1756-L65
Answer
There are two hardware changes to the Series B controllers:
New battery circuit for extended battery life. Uses 1756-BA2 "blue shrink wrapped" battery.
Compactflash card slot relocation under front swing door. Now the CF card can be removed without pulling the processor from the chassis.
Edit: Ken beat me to the punch.
Good Evening , We are getting ready to replace some machinery and the manufacture is planning on using a 1756-EN2T . What is the difference...
7,773
Is there any difference between these batteries other than the connector style? We have a ControlLogix L61 processor with a dead 1756-BA2 battery...
14,368
Hi, What's the difference between Rockwell Controllogix 1756-ENET and 1756-ENBT card? Are they compatiable? Thanks,
8,204
Guys, I'm configuring a redundancy system (network, CPU, power supply), i used to use 1756-CNBR at the remote chassis. I'm not sure what is the...
11,407
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,412
