How do I Connect DH485 Industrial Network to Local Area Network
wiwie
Jun 2008
PASURUAN
17
In our work area using 4 pieces PLC SLC5/03 that connects the DH 485 Industrial Network using 1747-AIC, how can we be monitoring the production process from the office through Local Area Network ( LAN ), (what equipment is needed and how to install and setup)
You could build a DH485 bridge and put them on the Ethernet
1756-A4
1756-Pxx (power supply)
1756-DH485
1756-ENBT
What are you are you going to do with it once its on the network?
Do you have a 485 network now? so if you hook into the AIC can you see all nodes now?
These are not very cheap but they work good, I am going to build one next week so if you email me I will let you know how it works....
I have built a lot of DH+ bridges but not a 485 (yet)
Search here as there has been some talk about this in the past couple of weeks and there may have been other ideas
Hi, I have a SLC5/03 connected to a working HMI via RE232 port, and connected to a broken HMI via DH485 (RJ45), I want to use the cable that used...
3,348
I have a 2711-T10C3 series E and I am experiencing a problem. I do not know the Panelviews very well. I have a back-up unit that I need to...
3,700
Greetings, I had an issue with a RIO rack 2 and IFM I/O Link dropping on my network. I would loose connection for a second or 2 then they would...
104
Hi friends, i need a help to know the procedure and steps to connect Lenze i700 to PC for parameterize. i tried with lenze easy-starter using LAN...
58
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
75
