FactoryTalk View "System\Time" tag
rleon
Aug 2008
Baires
129
Hi:
I am using the "system\time" tag to show the server time in the client computers (FactoryTalk View 8.2 SE). The problem is that the string display that I use is showing incorrect hour. The hour is UTC -4 and it's showing UTC -3. All computers are in the same time zone with UTC -4, with the same regional configuration. Same as the server.
The same problem occurs if i use the "system\hour" tag. For example the server has 10 AM and the numeric display shows 09 AM.
I don't wan't to use "Numeric and Time Display" because it shows the local computer date/time and I wanna show the same server time in the client computers.
What I am doing wrong?
I have not seen this issue before, but is it possible there is a setting for Daylight Savings time
Hello Guys, I've inherited a system that manages the bulk material loading onto 4 reactors. The system is built on an SLC PLC and the majority of...
22
7,043
I’m trying to use two string parameters as a title. I have a caption like: /*LS:0 {#100#101}*/ If #100 = Cat and #101 = Dog I get “#100Dog” Not...
2,242
V 10.00.01 Patch 6 Having a bit of a tiff with View SE. Ideally there would be a memory tag or parameters file with a color value that could be...
3,237
Hi, I am having this rather strange issue. In my FTView SE application (FTView SE 6.1), I have an area where I display current time and date. I...
6,106
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
129
