SLC500 unknown decompile error with fault
cryptius
Jun 2008
Michigan
We have a fixed SLC500 model 1747-L40A series C with 1746-A2 series A two slot expantion. It worked a year ago, but now has a CPU fault. When trying to get online it gives an unknown decompile error after it uploads. Tried using RsLogix ver 7.00, and an older version on an old windows 95 laptop. I found and tried using the A.I.500 upload utility but that gives error 17 decompile error. There is obvious com link as it shows the program number when connected and it tries to upload. We could really use to get this program off of it since we don't have a copy. Even if not, how can I download something new to it when it won't even go online? I found documantation on how to reset SLC500's to factory default, but it says that series C can't be reset. Please help.
I have already looked at both those links. As stated the upload utility doesn't work either, and I didn't come up with anything in the other links. I did a considerable amount of searching online before I posted here. I must say that most of the answers I found were on this forum so it seemed like the best place to get help. I am wondering if the PLC is now just an expensive old brick.
Ok, assuming that the program has become corrupt and can not be recovered, can I use the upload utility to download a blank program to it so it can be accessed with RsLogix? If the program can't be recovered I at least need a way to force a download to it.
I have a slc500 plc 1747-L30A. Using a communication cable 1747-PIC cable box combination. Running a version of software from DOS on a Windows 3.1...
88
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
297
can the slc500 5/05 send a email and text over Ethernet ?
196
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
401
Customer is buying several spare 504 CPU's to have one handy when there's an issue with the ones in operation. Having them on the shelf for years...
2,865
