RS5000 function block
g7283jl
Sep 2012
Kearney
I need help with converting a ladder program to function block.
The program is a basic motor stop/start circuit with seal in with a Run/jog switch.
I set up the function block program for the motor stop/start citcuit with seal in but can't figure out how to set the function block with the run/jog switch.
Welcome to the Forum !
I strongly recommend that you provide a screenshot, rather than a general description, of the RLL logic. I can think of a handful of different ways to logically implement a "jog" switch.
Stop Start CR
| Run / Jog CR |
Stop Start CR
| Run / Jog CR |
Hi g7283ji
if you are running windows 7 use the snipping tool on your actual program
or download MWSNAP 3
either of thee will allow you to post a JPG as per sample
the run /jog switch needs to be in series with the hold in contact
in the Run mode it allows the relay coil hold in.
In the Jog mode, the coil can only be energised when the button is pressed
DISCLAIMER: we might not be talking about the same "function block" ... if so, feel free to ignore this post ...
but ...
if you mean Function Block Diagram programming (FBD) then the figure below might be helpful in giving you some basic ideas ...
I'm just curious - but why on earth would you want to make this type of conversion? ... (school assignment perhaps?) ... many (most?) people would consider this type of control much better suited to programming in Ladder Logic rather than in Function Block Diagramming ... (but then again, maybe I'm just misunderstanding what you mean by "function block") ...
All, I am trying to get the minimum value of a temperature signal supplied to RS5000. The MINC function will only show the assigned 'RESET'...
1,843
I have recently made a career change after 25 years of being an electrician. I am officially a junior automation controls programmer. I recently...
395
Hi Guys, Hoping that someone could please confirm if the 1756-IF16/B is/isn't compatible with the 1756-L1 5550 processor(13.24). I'm sure I...
125
Hello, I need help making a logic modification to a RS Logix 5000 program. I can email the program and give plenty of insight to it plus I have...
2,227
Hey folks I was wondering how one puts shortcuts on the logic display for instructions. A few weeks back another programmer added them for me...
1,001
