plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 11th, 2019, 10:21 AM   #1
BrockSamson
United States
BrockSamson is offline
Convert old 24AC pnematic solenoid valve to new 24DC solenoid valve with rectifier?
I have an old piece of machinery that has a 24VAC pneumatic solenoid valve (5 port, 4 way, single with spring return and 1/2 inch inlets and outlets). I am in a hurry to get a replacement and cannot find a manufacturer that keeps them in stock.
Could I use a rectifier or converter to change the power from 24VAC to 24VDC so I can just buy a 24VDC pneumatic solenoid valve replacement?
I am new to this stuff this might be a stupid question.
Old February 11th, 2019, 10:44 AM   #2
T Gibbs
United States
T Gibbs is offline
Have you looked at Automation Direct for a valve?
Old February 11th, 2019, 10:53 AM   #3
gclshortt
Canada
gclshortt is offline
gclshortt's Avatar
https://www.automationdirect.com/adc...TC%20Tubing%22
Looks like Automation Direct has this in stock.
Yes, you could use a 24VAC coil of a relay and drive the new 24DC solenoid with the contacts of the relay with a 24VDC supply.
Regards,
__________________
Garry
https://www.accautomation.ca
Connect with us on Facebook: facebook.com/accautomation/
Old February 11th, 2019, 10:56 AM   #4
lfe
France
lfe is offline
Yes, it should work.
__________________
Suppanel HMI
Old February 11th, 2019, 11:32 AM   #5
Archie
United States
Archie is offline
A full wave rectifier will turn the 24VAC into a "rippled" DC voltage. The RMS will be 24V, but the peak will be over 35V.
__________________
Expectations lead to disappointment. Appreciation leads to satisfaction.
AdvancedHMI - HMI Software without the license key hassles
Old February 11th, 2019, 12:41 PM   #6
BrockSamson
United States
I guess that is my only option. Thank you.
Old February 11th, 2019, 02:08 PM   #7
BrockSamson
United States
The one they sell on automationdirect is 1/4 and I need 1/2
Old February 11th, 2019, 02:41 PM   #8
RClem
United States
RClem is offline
RClem's Avatar
This would fit the bill at 24 VDC:
https://www.automationdirect.com/adc...)/avs-5414-24d
Old February 11th, 2019, 02:44 PM   #9
BrockSamson
United States
Thanks CLEM. I have seen that one but the problem was finding one in VDC so I guess the only option would be using a relay to drive an addition 24VDC power supply to power that particular one.
Old February 11th, 2019, 04:19 PM   #10
Jeff23spl
Canada
Jeff23spl is offline
interface relay will make sure you don't fry anything in case the new valve need more power than the old one...Take a look in the controls, maybe it is already a relay that drive it ?
__________________
Siemens Addict
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Two Destination Flow Split - Most Open Valve w/o pressure? Lakee911 LIVE PLC Questions And Answers 6 March 9th, 2017 01:57 PM
Double Solenoid Valve , three position valve? Tofo LIVE PLC Questions And Answers 9 October 29th, 2013 08:20 AM
diagnostics of a cylinder driven by a double solenoid valve Bartech LIVE PLC Questions And Answers 11 August 21st, 2012 08:40 AM
Using AB Micro830 to control servo valve and solenoid valve. ivanlch LIVE PLC Questions And Answers 3 August 8th, 2012 03:35 AM
OT: solenoid valve w 460vac coil OkiePC LIVE PLC Questions And Answers 9 November 22nd, 2005 10:03 AM
