S7 1200 (4 PLC's & 4 HMI)
boneless
Feb 2008
OKC
1,628
Hi all!
I have 4 S7 1214C PLC's, each with their own HMI.
I want to be able to set select set points from my main PLC (1 of the 4) and visualize some of the information. All PLC's will be interconnected by PROFINET.
In your opinion, what would be the best way to read and set the data?
This is what I am thinking, in no particular order:
1. PUT/GET
2. CONTROLLER/DEVICE
3. Just use the HMI
Perhaps there is a better way?
Thanks!
I'm a fan of I-Device (controller/device as u said). Fast, no code needed.
Put/get are simple, but a little too magic for my tastes. Only one PLC gets status.
Hello, I have a small application with a S7-1200 CPU 1212 and a KTP400 Basic HMI. When i am connected to the PLC with my PC i would like to...
557
Hi Complete newcomer to S7 so go easy on me... Siemens S7: What cable do I need to connect S7-1200 PLC to HMI? The touch screen is one of these...
2,633
Hi I have S7-1200 and want to use a general PC as HMI with TIA v.13 1) what additional hardware my PC should have? (it already has a TCP/IP...
3,930
:yakyak: :bow: Reported Issue : Siemens HMI does not Communicate with Siemens1200 PLC. Sequence Of Events : Checked status of HMI and PLC and...
5,449
Hey guys! Newbie here, have some experience in both S7 Classic and TIA V13, but would really like your opinions/help on a solution...
37
25,265
