Processor fault
gmultani52
Oct 2003
75
Hi
we are having slc 5/5 in our plant due to some trouble production line stoped. plc processor indicate fault. we donot having processor key. can we rest by power off/on of processor.
Only minor faults like math overflow errors can be cleared with the keyswitch. A power cycle will clear major and minor faults, but generally the controller will recover from a fault by going to Program Mode.
Major hardware faults will recur after power cycle, so you might need to diagnose this controller with RSLogix 500.
To switch from Program to RUN modes, you need either RSLogix 500 software or a key.
These keys are not complicated; you could probably use a bent paperclip to rotate the switch.
I just checked my desk at home; two SLC keys in there, one on the keyring, another in my computer bag. These are also the keys used on the ControlLogix. I'll bet your local A-B dealer would give you one for free.
Hi Guys Today we went through the worst situation that PLC went to major fault Mode due to Trap by one of the Timer with -ve Value Moved into...
1,028
Good Morning , I have some new Powerflex 525 Drives - This morning I got a F 114 uC Fault. Sounds like it is an issue with the microprocessor...
13,855
Any idea why a MSG instruction (see attached screen capture) would cause an L81E Processor to crash hard with a T01:C61 Fault? After the fault the...
14,124
Hello all, I am in need of some advice here. We had an issue with our waster water treatment plant here a week or so ago with one of our...
3,119
I have a SLC 5/05 processor with a Major Fault 1F39h. The processor is running fine with the fault, but I would like to know what is causing it? I...
3,835
