Deleting IPOS and/or Encoder with Keypad for SEW Eurodrive Movidrive Compact
Coachman
Sep 2006
Maryland
97
I am in a need to replace a SEW Eurodrive Movidrive Compact drive
to a fan application ,but I need to use a drive that is for another
project, and I am using a Master/Slave. How can I delete the IPOS
section so it does not look for the encoder. I am at another
location, and the cable and adapter are not availible.I only have
the keypad. I chose 802 Factory Settings ,but it is still looking
for an encoder.
Thanks in advance,
Not sure if you can via the keypad...
But something you may want to look into, I have hook direct to a Movidine before (not sure if you can with the Movidrive) the Movidine had both 485 and 232, the 232 were under the face plate.
Can you remove the IPOS card? on the older ones they were a add on, if you removed the card it was a just a drive (with out positioning)
These are just WAG's can you post you exact part number/model it may help
Hi, I have a s7-1200 at home that went into "CPU error: Serious firmware exception". After a power cycle it was OK again, but all retained data...
839
Hi guys, Working on one of my client's systems with SLC processors, earlier today she called me and said she was having comms errors, had a solid...
2,041
Hello EtherCAT gurus. Is it possible to delete the EtherCAT Stack Code information from an EtherCAT device using the available Windows tools...
1,280
Hello: Richard here, new to the group. We are learning Studio 5000 in my advance PLC class at school, but greatly limited by not being able to...
1,744
All of these processes are taking all day to run. When doing the same operation in a stand alone intouch application it only take a few minutes to...
1,604
