s7-1200 error and deleting retained data
rQx
Oct 2010
Trelleborg
1,051
I have a s7-1200 at home that went into "CPU error: Serious firmware exception". After a power cycle it was OK again, but all retained data was lost. Is there a way to prevent this from happening? Not the CPU error, I guess it can happen. But the retained data? Can a memory card in the CPU prevent this? I thought the retained data was stored in the CPU. Maybe the issue was that it thought the memory card was changed? (I have no memory card in it)
After the power restored it said:
Security information: Memory card exchanged during power off - current card type: No memory card
Security information: PLC project changed Load memory control
I would make sure the firmware is up to date, people seem to have reported this in the past. A few years back I had a couple of PLCs loose their program entirely. I upgraded firmware and wondered about power supply issues, so I added Varistors to my 24V d.c. circuits on top of existing back emf protecting diodes.
Thanks I'll do that
/Tim
Hello all, I am working on a project using an s7-1200 and tia portal v17. The project is for stepper motor control for a SMD23E2 motor. I am...
5,296
Hello, I'm working on a project where I want to communicate with two GP230 drivers using a S7-1200 (1214 DC/DC/Rly) with a 1243-5 profibus...
4,437
Having a problem and spent quite a bit time on that. I can read whatever I want from this particular modbus device, but when I want to write 1...
4,947
System is an IPC547D running GRAPH in WinAC RTX. Six S7-1200 (CPU 1215C) running a little code for manual operations, but mostly running as...
8,000
Hi, I am operating a Micrologix 1200 PLC whic has come up with a fault light on power up . When i go to the STATUS file under errors it says...
28
7,751
