Connect Vacon 100 VSD to ControlLogix through Ethernet/IP
jokerb
Jan 2013
HOOD
I am Using a Vacon 100 VSD and I want my controllogix plc to talk to it through Ethernet/IP.
I know the PLC and the VSD are now talking because I keep getting a Invalid Segment type error.
I believe my problem is in the configurations but the ethernet/ip manual for the drive is very limited and Allen Bradley support team told me I need to get more data from Vacon.....
Has anyone here tried to connect a controllogix to a vacon drive before??
have you looked into Modbus via e/net
look at kepware Kepserver V 4.6
Not sure off hand but might be the answer.
welcome to the site
Where in Aus are you
In South Australia,
I figured it out. The config in Rslogix 5000 was incorrect
I inputed the correct instances and size bits but the config was suppose to be 103 with bit size 0.
Cheers
86
89
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
105
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
337
What has been your experience with year over year price increases on your Tech-connect service contracts? Is it up to the distributor? 30% seems...
288
