Micrologix 1400: AWT instruction is not working in CH0
asteroide
Jul 2010
der
158
Hello friends
I am trying to communicate a ML1400 with a production display. I need to send 2 bytes and I receive 32 bytes.
I have done this with a ML1500 (COM1=ASCII) a RS232/RS485 converter to the display. It works fine.
I need to do with a ML1400, because is the PLC that is in the plant, also it has RS232/RS485 combo port in CH0, so I could eliminate the RS232/RS485 converter. (ML1500 is the PLC that I could get first to do trials).
Now, I have a ML1400 to do trials. From the ML1500 working program, I have changed ML1500 to ML1400 in controller properties, channel 1 to channel 0.
But, AWT instruction is not writing. No error code is present.
I have done a test: using CH2 in ML1400, with identical parameters for CH0 and the converter, and it´s working in CH2¡¡¡ But, this Channel 2 has not RS485 option, so I can not eliminate the RS232/RS485 converter.
I am attaching the ML1400 CH2 working program.
Why AWT instruction is not working in CH0?
What do you recommend?
Thanks in advance.
Under the Protocol Control section, change the Control Line selection from "No Handshaking" to "485 Network".
That switches Channel 0 from using the RS-232 pins to using the RS-485 pins.
Hi! I have a setup where a sensor senses an object and sends a signal to the PLC. The PLC has to send an ASCII character to the PC for triggering...
1,123
hi to all, have anyone tried to communicate Schneider PM800 to a ML1400 through rs485? i am having an issue with it just receiving message...
51
113
141
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
262
