Alternatives to Rockwell NAT devices ?
Is there a non-Rockwell alternative to the NAT devices from Rockwell: the 9300-ENA or the 1783-NATR ?
Tons. I'm willing to bet that almost every industrial networking vendor has a NAT capable device.
From Siemens: S615 gets you NAT capability
I have a Stratix here doing NAT conversions. I did not set it up but its been running here for some time now. I only mention it to make the point that I think you can do this with most decent Ethernet Switches. We have large 48 port Cisco switches here that do some NAT routing on the office side.
I had a salesman here once back in the day talking about the capabilities of his switches including the NAT translations. He sells the Phoenix Contact brand.
Id probably look for alternative as well if I was spending my own $$ on this stuff. I usually use the 1783-NATR but even they exceed a cool grand to purchase one. I use one on every project so I bet it would scare the folks here to know what they spend on these each year...
Hi I am interested in alternative (secure,audited) soltions to Assetcentre 25 assets is enough. Will be Archestra, Inbatch, RSLogix5000 plus a...
2,493
We have a critical alarm system that uses Win-911 paging software that talks to an annunciator panel using a Modbus driver. The software runs on...
543
Greetings! I have used IFM IO-Link devices for a while now from IFM and they have worked out very well. Unfortunately, IFM is among the many...
2,373
I’ve recently been given several IB-32 and OB32 digital cards for an AB SLC500 that use the 32 pin plugs to a breakout board of some sort...
692
Hello, Does anyone have suggestions for an alternative to the AB 1783-NATR router? I need something in similar physical size but hoping to find...
3,808
