Produced and Consumed tags
kbradray
Jan 2006
Columbia
175
I am trying to create a produced tag in a compactlogix L32E to be consumed by a contrllogix L61. I have a tag created in the L32 called Produced_Mass_Spec. It is set to be consumed by 1 consumer.
When I try and set up the Consumer tag I cannot figure out how to do it.
1st i cannot do it online and when i try and do it off line the program uploades and deletes the newly created tag.
2nd when i try to create the consumed tag i cannot get the connection correct
the L32E is 192.168.0.48 and the L61 ENBT is 192.168.0.100
Please see screen shot of the producer.
Any help is greatly appreciated.
Produced and consumed error
I am a bit closer, but now i get an error saying (multicast/unicast) not supported.
I installed the controller in my I/O configuration window. I could then get the dropdown for my connection on my consumed tag. now i am getting an IO communiation fault.
Help please.
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
160
Hi I have been knocking my head against the wall trying to figure out why these two plcs won't talk with Produced and Consumed Tags data. The...
474
Hello all. I have a 1769-L16 that I inserted a 1769-L35E into. I was expecting it to create module defined tags automatically in my controller...
1,814
Hi, Can a tag configured as a Produced or Consumed tag be read or written to with Explicit Messaging? Context: we are retrofitting an AV system...
2,242
Ok, I've setup comms to PLC's that are behind a NAT switch before, but I have not had a PLC behind one NAT switch communicate with a second PLC...
3,429
