ultra 3000
Adam303
Aug 2009
Chicago
587
Hi to all.
I have been trying to learn motion control with an ultra 3000 servo controller. I have a question regarding the unit. Can ultra 3000 be used to deal with motion as a standalone unit or does it have to be integrated with a PLC. I’m using a SlC 5/05 and was thinking about using a 1746-HSRV card, but I’m not sure if it can be used with ultra 3000. Can anyone help and point me in the right direction about how the ultra 3000 controller works. I do also have the Ultra Ware software.
If you have an indexing version of the drive (part number ends in X, i.e. 2098-DSD-010X) then it can be used as a standalone unit. Motion profiles are programmed using Ultraware and then initiated from the digital I/O. You still need some type of PLC, or possibly just a small smart relay, to interface with the digital I/O. For extremely simple applications you might be able to dispense with the PLC, say by triggering the motion start input with a foot switch or something.
If you don't have the indexing drive, you will need an external controller like the 1746-HSRV. However, I'd suggest sticking with the indexing model unless you have advanced requirements like coordination between axes.
Hello All, Question about an AB Ultra 3000 servo drive (with DeviceNet), perhaps someone has seen this before... On power-up, the green LED for...
1,645
We are pulling our hair out trying to figure out this issue. We have an AB*MPL-A330P-HK22AA servo motor that started randomly throwing E22 and E24...
2,606
Hello All, I am having an issue with a Ultra 3000 jumping while stopped. It seem to be intermittent. I am using RS5K to control the servo. It...
2,599
Hello everybody, I need some help. I have flying shear application and trying to upgrade drive. Here is parts I planning to use: Ultra 3000 wit...
1,462
Hello everybody, have a question, is anybody try to use serial port to control Ultra 3000 Drive, I have project where customer want to upgrade old...
2,655
