Wonderware System Platform 2014 R2: Unable to deploy galaxy node
letandat
Nov 2016
Ho Chi Minh City
Hi everyone,
I am using Wonderware System Platform 2014 R2 to do my thesis, I have create a galaxy and platform, app engine, view engine in my galaxy and a intouch application, they work very well.
And now I want to add other platform, it is a computer in the same LAN network with my computer. But when I deploy it, I get the error as this image.
Error: Failed to deploy WinPlatform_002 : Failed to get the bootstrap's version.
And other problem: When other PC in LAN network connect to my galaxy in my PC, it has the error: Unable to connect to galaxy.
Is there anyone has the experience in these problem? Please help me to find the solution.
Thank you very much.
http://esupport.wonderware.ch/Data/ReadMeIAS35.html
"Remote Platforms are unable to be deployed if the Galaxy Repository and remote nodes have same domain user, but one is specified by the fully-qualified domain name (mydomain.xxx.mycompany.com) and the other by just the domain name (mydomain). The following error message is shown: "Error: Failed to deploy WinPlatform_002 : Remote Node's UserId/Password don't match GR Node's."
To work around this issue, make sure that the user\domain\password match identically for the nodes. Either both nodes need to use the fully-qualified domain name or both nodes do not."
Did you see the above link on the Wonderware Application Server 2012.
It may help you out.
Regards,
Seems odd that you can make a symbol and place many of them but if the text on a button and or elsewhere in the symbol comes from a Custom...
1,678
I was given some example code but I can not get the function to show up in the System Platform script. The dll import is successful but I'm...
2,072
Hello Everyone! Need help with this... I have a controllogix plc 5571 which has just a USB port on it. I wish to read the data from this plc...
2,410
Need your Advice. Scenario: I have got two SCADA computers at different locations which are having independent working plants at each site (But...
2,987
Hi all, This is my first System Platform 2017 install. Have done plenty of mods to existing 2014 R2 installs and know what I'm doing in terms of...
5,141
