Wiring npn sensors and push buttons
papejo
Feb 2014
mexico
35
hello, membes of this awesome forum , i have a question about wiring npn sensors and push buttons.
i have a jazz plc, the plc has two groups of inputs : from i0 to i5 and the second group is from i6 to i7, the machine has 5 npn inductor sensors and two push buttons.
so i set the first group of inputs as npn and the second group as pnp for the push buttons. see wiring diagram 1, is it correct?
now , lets imagine i have to configure both inputs groups as npn , how do i wire the push buttons? is it correct as i did in wiring diagram npn?
im sorry for my bad diagrams made in paint, i dont have no cad install in this pc.
I can't say I've ever heard of a jazz PLC, but you seem to have the concept right based on your sketches
Jazz is part of the Unitronics lineup, I think. Haven't used them, but the wiring diagram appears correct. I would tend to try to make all the inputs the same to aid in troubleshooting later.
i am thinking the same, making all inputs npn, but is it ok to interrut 0v on the push buttons?
This is just a personal feeling on switching 0V. It makes it a lot easier to fault find if everything is the same switching. (potential)
Here in South Africa we only use positive switching, or live switching (hot for the guys across the pond).
In a life ago, I started at a new company with a lot of American built machines. The only gripe I have about them is the 0V switching. It caught me off guard and sent me around in circles till I figured out the 0V switching. Don't get me wrong, they are solid and well built machines, just the switching had me confused.
papejo said:
...the machine has 5 npn inductor sensors and two push buttons....
...so i set the first group of inputs as npn and the second group as pnp for the push buttons. see wiring diagram 1, is it correct?
now , lets imagine i have to configure both inputs groups as npn , how do i wire the push buttons? is it correct as i did in wiring diagram npn?...
While you appear to have grasped the basic concept of Sinking and Sourcing Inputs, I would say that technically neither schematic is correct for what you have described. While I know that it is a very simple presentation and most likely you will not be wiring it up exactly as you have shown us, I feel it important to answer your question honestly, for your sake and perhaps others. I do not know your level of experience and so I cannot assume you were just taking a "shortcut" in your schematics. You could be making a fundamental mistake. My gut says you are not, but who knows?
So, can you tell me what it is I have spotted that looks incorrect for what you have described?
Remember, even if you were just taking that "shortcut" and you think I am being petty by bringing it up; there may be others who are reading this thread who are not so experienced and would be possibly misled by such a simple thing. And of course, it will not sit too well with us pedantic creatures.
To the rest of the Forum members, please let papejo answer this themselves.
Regards,
George
Regards,
George
Hi, thanks for the answer, I’m a beginner, this would be my third job of this kind, about the diagram, i did take a shortcut wiring the five sensors, I shouldn’t just draw one sensor but the five sensors instead , you are right it might confuse someone.
Is it ok if I configure all inputs as npn including the push buttons, or do I wire the push buttons as pnp
papejo said:
Hi, thanks for the answer, I’m a beginner, this would be my third job of this kind, about the diagram, i did take a shortcut wiring the five sensors, I shouldn’t just draw one sensor but the five sensors instead , you are right it might confuse someone...
OK, that's fine and thank you for understanding why I brought it up. Sometimes a small but incorrect detail, or an omission, can make a world of difference in this game.
papejo said:
...Is it ok if configure all inputs as npn including the push buttons, or do I wire the push buttons as pnp
You sound like you are looking for definitive answers when really there are none. All you can do is assess the advice given, which will undoubtedly vary on this subject, and come to your own conclusions.
It is OK to configure all the inputs for NPN devices if that is the signal type that must be connected directly to the inputs.
The push buttons are not biased. They are merely switches. So you can choose to switch negative or positive and both methods will work. You do not have to wire the push buttons the same as the sensors.
Now that you know that you can do the above the next question is should you?
Some earlier PLCs used NPN I/O exclusively but due to growing concerns over safety risks the industry has adopted, in the main, the PNP option, or at least the ability to configure for both. This is because NPN I/O will inadvertently drive the load during a short to ground of the signal wire which may create a risk or produce undesired results. Whereas PNP I/O will short positive to ground and pull down the supply, preventing the load from being driven. This is based on the premise that ground shorts on the signal wire tend to be more prevalent than shorts to positive.
So, in that regard, we could say that using PNP I/O is less of a risk than using NPN I/O but there is still nothing to stop you using either.
Should you mix types in the one system?
Again, this is a matter of opinion, preference, or specification for many of us. But sometimes you just have to deal with what is before you and cannot dictate either way. So a mix may be inevitable. If designing from scratch and you can choose then I would recommend PNP I/O for less risk, better standardisation, etc. But it really depends on what systems or processes you are dealing with. Some electronics are going to use NPN logic specifically and there is nothing you can do about that when you run into it.
You can always interpose undesirable signals to convert them to the logic you require or prefer so as to keep to a standard and not have them mixed. Having differing common polarities on the same I/O module is not ideal and clear labelling and schematics is highly recommended in such cases. Another option, where a mix cannot be avoided, is to use isolated modules for the opposing signals so as to segregate PNP & NPN I/O. But that costs money and small systems often cannot justify the use of a separate module for say a few NPN inputs in a primarily PNP input system.
Both are acceptable methods and both will work but my experience is that PNP I/O is more the industry norm nowadays and NPN I/O, where there is a choice, is less desirable from a safety point of view. Which you should use and whether or not you should mix them is, at the end of the day, really up to you.
Regards,
George
Dear all, I am a student. Please share on the right wiring of the attached PLC (Panasonic Nais FP1-C40. I am using AC connection and able to...
3,635
Hi there, I have a 2 wire npn sensor. For example in this diagram: I'm guessing i should connect it to a PLC dc sourcing input as such? Would...
5,214
we use an embedded plc controller that is configured as npn. We have the following problem now. When we do not put power on the plc (24V) but we...
3,869
Posted this to Reddit with little success, so I figured I would share it here as well. Very new to PLCs, but figured I would give it a shot to...
122
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
76
