WinCC Flexible Runtime SCADA Communication with 8 or more s7 200 plc
Feb 2011
vadodara
Hello all,
I want to Control & Monitor 8 different S7-200 CPU 226 PLCs through Wincc Flexible SCADA.
I am trying to communicate through RS232/PPI multimaster cable, but right now it is communicate only through one S7-200 PLC, not more than one S7-200 PLC in PPI network.
I cannot add more than one communication driver of "SIMATIC S7 200" in connections option for PPI network in SCADA.
so which communication cable I will need & network I will select to communicate these 8 S7-200 PLCs with Wincc Flexible Runtime SCADA software ?
If anyone have any idea regarding my question then please reply me as soon as possible.
Thanks a lot in advance.
Regards,
Punit Patel, Vadodara, Gujarat, India
Multimaster PPI network works only when you have a network composed only of S7-200 PLC's.
Once you enter a Simatic HMI and/or a S7-300/400 PLC, the S7-200 need to be referenced as MPI-slaves.
Depends on the panel you're using though, which you haven't mentioned....
Thank u Jeebs for your reply...
I am using Wincc Flexible Runtime SCADA on a PC.
I want to get data from 8 different S7 200 PLCs (CPU 226).
so which communication cable & network configuration I will need to get data from PLCs?
i cannot transfer a wincc flexible 2008 sp3 project to a pc station (which has wincc flexible runtime 2008 and cp5611 communication board). i...
7,415
Hi! I have a pretty awkward problem on my runtime system. It's connected to a s7-1200 and this s7-1200 calculate PartsPerMinute(PPM). Every time...
1,215
I am trying to find out if there is a way to "read" the tag comments in WinCC Flex 2008 (SP3) during runtime. I'm using WinCC Runtime on normal...
3,881
Hi! I have a Wincc Flexible 2008 Runtime system with archives connected to a s7-1200. This system logs "on change" and this is controlled by the...
2,897
I would like to start a intresting thread about wincc flexible. How many of you are working projects with a lot of panels? And panels are...
2,289
