Global connection displays every second on Information Messages?
KingPresident
Aug 2015
Michigan
138
A tag from Global Connections of Date and Time using 'Seconds' as a heartbeat monitor at the PLC. It is displayed every second that ticks by on the Information Messages Screen.
Is this normal? Is this something I can disallow? Not really a problem, but it confuses the children.
It's normal, but it should go away when you close the information display. Does it?
I found it annoying regardless and just go with the "minutes" as the smallest time units these days.
Hello, I'm trying to close an on top display using global connections. I'm using FTView ver 11.0. I have watched You tube videos and read many...
2,389
in FTV ME Version 9.0 i want to have 2 tags for the global connection "Replace Display Number" - is this possible? i have 2 plc short cuts...
1,322
Hello everyone, I have one question for old project FT. the global Connection remote display number, its set is If NOT {PLC_Communication_Lost}...
2,250
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
129
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
169
