AB Servos with Yaskawa motors
phuz
Jun 2008
Mohnton, PA
1,044
I'm stepping outside my wheelhouse a bit. Can AB Kinetix servos be used with other servo motors (in this case, Yaskawa). I'm looking at a controls upgrade and we want to rip out the old Yaskawa servos and replace them with Kinetix. Ideally we would replace the motors, but cost may become a factor in swapping all of them.
No, that is not possible. Yaskawa uses proprietary encoders, so in general, the motors only work with Yaskawa drives. I would stay with Yaskawa. Once you start replacing motors, the project usually becomes much bigger. Often leads to new mounts, couplers, gearheads, etc. Depending on the motor, you could replace the old drives with new Sigma Logic drives. They use add on instructions to make it easy to use with Logix 5000.
I have 2 servos that is moving a gantry. I am planning to use one to follow the other using an MAPC command, but when I home, could I tie the home...
1,383
I have a unique project and will be commissioning it next week. It involves two servos that are both connected to the same belt in an H-type...
22
14,122
Hi All, We have encountered a problem with one of two servos that feed paper. The infeed roll was replaced and diameter of a new one is slightly...
2,179
Good Afternoon , I have a machine that has 7 - Kinetix 6000 servos on it . All the servos want to run high speed and cannot slow down...
2,154
Hey guys... I'm in the middle of a battle with the boss because when I try to tell him what I need he claims I don't know what I'm talking about...
2,979
