Can you home 2 Kinetix 5500 servos with one sensor?
Blueshard
Jun 2011
Longview
I have 2 servos that is moving a gantry. I am planning to use one to follow the other using an MAPC command, but when I home, could I tie the home sensor to both amplifiers, or would this cause unexpected issues?
Thank you for your help.
if in doubt you could always use the sensor to pull in a relay and have the 2 circuits for homing completely isolated switching through the same relay?
Thank you all for your input. I did get the opportunity to discuss it with Allen Bradley as well. They did say it could be done with one sensor, but the second amplifier would have to be geared 1 to 1 and provide a mark of some kind to verify the 2 servos were parallel. They also suggested I monitor the current from each amplifier and make sure they produced close to the same value. If the value got too far from each other, there is the likely hood one motor was leading or lagging behind the other.
Saying all of this, they did suggest the best solution would to add a second sensor. When homing, move the (A servo) in to home while (B servo) is a slave. Move back a few inches, switch master and slave and home the other servo completing the homing procedure.
Hi all, I am commissioning my first servo drive, and I am trying to home my servo but unsure how to go about it. I am programming a gantry...
1,457
Hi, Does anyone have examples on how to home a Kinetix 5500 servo using current instead of a input?:scratch:
3,604
Does anyone know these drives that can help? I need to move a home position on a drive by -500mm. I've physically got the carrier in position, but...
1,746
The homing watchdog timer preset was changed to 60 sec from 30 sec due to servo homing taking too long. The home offset is around 180 degrees...
1,929
Hi, I am trying to home the Kinetix 300 drive using the home to sensor option, but for some reason:huh: the cam always goes past the home sensor...
4,658
