TIA Portal - multiple programmers, 1 project?
Jul 2013
Here
31
Imagine an automation project with several sub stations with each a PLC.
But they all have to be connected via network, e.g. S7-connections, like you would create within one project's devices configuration.
Can multiple programmers collaborate in one project, using TIA Portal?
We have V11, if that doesn't support it but V12 does (or V12 is much more stable, for that matter) we might upgrade.
From going through every menu in V11, though, I see no special functionality for something like that, while over a year ago some Siemens person talking to us said that TIA would allow to collaborate...
Certainly not in the way of PC software development, given the binary project format.
Even if TIA does not by itself support it - are there (not too painful) ways of doing it?
What do you do?
Regards,
-PTPP
Hi everyone As a topic title, I want to edit ALARM01_1 ALARM02_1 ALARM03_1 .... ALARMxx_1 to ALARM01_2 ALARM02_2 ALARM03_2 ...
416
Using TIA Portal v17, SIMATIC S7-1500 PLC. I am trying to write an alarm that will trigger for multiple sources, and output the triggering...
2,557
Hi Guys. A vendor is delivering a non GMP machine with a 1500 CPU and 4 panels. one TP1200 and 3 TP700. Im searching con/pros for according to...
2,111
Hey Guys, I am using a siemens IPC with a siemens RFID setup (Part numbers below). I am looking to create a screen where I can add/remove users...
122
i am using profibus, i want to insert a hexadecimal word or byte to 4 byte like in the phot but i don't know how
147
