MP 277 communication with RSLinx OPC Server
arun_mallah
Feb 2005
Pune
18
I am trying to communicate Siemens MP277 HMI with RSLinx Gateway OPC server. The RSLinx Gateway OPC server is running on a computer. The computer and the MP277 HMI are on the same Ethernet network. I am able to ping the MP277 HMI from the RSLinx computer. I have configured the MP277 HMI connection as OPC with the RSLinx OPC server. The HMI in runtime gives error "Couldn't connect to RSLinx...". Has anybody tried this earlier. Your early response will be much apreciated.
-Arun
DCOM issue?
Could be a DCOM issue. Even if you can ping the other PC, you generally need to be on the same domain or workgroup AND usually need to do a bit of DCOM configuration to get OPC communicating remotely. Firewalls can also keep things from working.
Here is a document on how to configure DCOM for remote OPC communications. It's a good reference on how to get data moving.
If you need to keep them on separate domains, traverse firewalls, or can't re-configure DCOM settings, you may want to try OPC Tunneller
Good day! I am currently working for a small project wherein a Siemens MP277 will be connected to another MP277 with WinAC via profibus. I've...
2,420
Dear friends, For past 2 weeks i struggle with this issue. i try to transfer the project from my siemens field pg to mp 277 through...
1,860
Hi everyone, I'm new at the communication between PLC and WinCC Flexible. So I made a few examples with TP panel. But we've bought an new multi...
3,793
Ok I've searched and Looked around for a few days now on the website and Siemens site and still havent found much to help me. So here is what I...
2,784
Hi everyone, I'm installing a MultiPanel 277 touch (MP277) on a machine where I've a Modicon PLC, the thing is that in order to have...
6,556
