What is the oldest PLC system you have running?
Just remembered a couple more a Ferranti system the plc controller & I/O blocks took up 4 double wardrobes where our S5 took one, we used the other wardrobes & replaced the I/O boards with Harting plugs & sockets pre-wired to the plc cabinet for a quick one day changeover. and another was some Swedish thing where the date was 1973, it had I/O boards where the analogue chips were metal top hat IC's with 6 or 8 legs, could not do anything as no idea who the actual Mfr. was, however, managed to find that one of these was faulty, replaced it with a spare channel (fortunately these were plug in).
http://www.sattcontrol.se/sida/sida3_1_1.php?select=meny3_1
Might have been an old PBS?
Oldest still running is 2 machines with AB PLC 2/16's.
Last year we replaced a Texas Instruments model 305, that we pulled the program out of using the embedded hand terminal.
Also replaced a GE Fanuc 90-30 last year.
Prior to that we replaced the AB PLC 2/30 dinosaur.
The TI305 was a rebadged Koyo,was previously marketed by General Electric as the Series One.They are still available through Automation Direct.
Wrong model - my apologies. The Hitachi ones were the ones I meant - cannot remember the model numbers now - too long ago. They were a black box I think.
Replaced a few of these old Moog Parison Controllers now, guy in Ireland had 6 Blow Molders with them on and they all started to fail at the same time. These were from an old Graham Engineering 10-Head Blow Molder. Fascinating to watch, but all done so easily in a PLC and HMI these days.
Last one we did was a water cooler bottle manufacturer in the States, he spent 6 months looking for someone to take it on and found us in the UK.
We were 7 days into a 2 week job and had to fly back to the UK because of the Covid-19, I managed to complete the job via the E.WON and some web cams the customer had bought, placed around the machine and a great many hours talking with the customer on Whatsapp.
Vid for the full flashing light effects: https://youtu.be/aHv2WKJlSng
Not strictly a PLC however we had a customer running a few of our machines using an S100 buss type PDP11 system.
I go to a National grid, gas fired electricity power station that produces megaWatts of electricity.
They have a Toshiba plc (EX40 with extensions) running the gas and air valves - like a huge carburettor.
I have offered to upgrade it many times but they have a spare. Anything goes wrong with it, they swap it out and send the faulty one to me to repair.
We have a 650T ( Yes 650 Tons) winch with controls that pre-dates PLC's. still using control components and pressure sensors etc from 1974' ish.....
We have a plan to replace this in 2022, but still in use
I think Modicon was one of the first controllers it was designed by Dick Morley it was made up of "MOdular DIgitial CONtroller." I believe these were in use in the very late 60's I replaced one that was fitted in 1972 (I think), it was replaced in 1997 with a Mitsubishi A series.
Ah yes. We ... replaced .. 4 pdp 11/03 (I think) that were actually mounted on mobile platforms (pallet stackers) ... the supervisory system was a PDP 11/70
I had forgotten about that. That was likely installed about the time that the original Allen Bradley Black Box PLC was released (1977-ish?)
Thanks for the walk down memory lane!
Wasn't DEC one of the two companies, the other being Bedford Associates, that responded to GM Hydramatic's "proto-PLC" RFP ca. 1968?
Perhaps it's an urban legend, but I heard that Bedford was chosen over DEC to keep GM IT out of the process, because, if DEC were chosen, then it would be a computer purchase.
Hello, I'm trying to connect a HMI G304 with the oldest toshiba plc's EX100, I was reading this hmi can use with this oldest plc, and I started to...
2,918
Hello, im quite new and still learning. I would like to ask is it possible for FATEK PLC to read data value more than 16k? I'm trying to move my...
55
89
HelloI need software to download the program from PLC EH-A28DRP from an old machine whose manufacturer does not exist. It may be Ladder Editor for...
99
359
