Redlion with oldest PLC
Kristian
Jul 2008
Guatemala
20
Hello, I'm trying to connect a HMI G304 with the oldest toshiba plc's EX100, I was reading this hmi can use with this oldest plc, and I started to work on it, but I can't connect, so I contacted with the support of Red Lion and they help me with no sucessfully.
So I was wondering if anybody can help me with this issue or can tell me what another cheap hmi can connect with this oldest plc?
Thanks in advance.
It does not specifically say EX-100, but the Crimson driver list does claim to work with the "EX series" and there are some limitations and exclusions spelled out in the accompanying downloadable driver literature:
http://www.redlion.net/resources/te...re/cables-drivers?field_manufacturer_tid=1436
EDIT: after looking closer and a little googling, I think you might be up against the "upgrade now" wall.
http://www.plctalk.net/qanda/showthread.php?t=9307
http://www.plctalk.net/qanda/showthread.php?t=69165
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
169
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
222
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
656
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
825
