RedLion DA50 - RS485 Wiring
moistcat
Jun 2020
Melbourne
54
Hi All,
Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485?
Is best practice to run twisted pair, common & shield to terminal blocks, then hack apart an RJ45 cable to get B+ A- and Comm to the RedLion?
Then cable from shield terminal to redLion GND ? EMC Installation Guidelines 2.A
Maybe a fancy RJ45 plug that allows external sheild and 1.5mm twisted pair cables to fit?
We had some discussion about terminating ethernet cable cables (in my case sharing one cable for two network connections):
It's not hard to strip the wires and land them in a terminal block, but if you want to just use complete patch cables you want something like this:
Definitely watch for polarity, if I recall correctly Red Lion and Schneider Electric disagree about the meaning of A/B +/- assignment.
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
173
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
658
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
827
Hello all, I am working on a DA70A flex edge data logger. I am it communicating with a computer on the network. I can ping it and everything looks...
393
