Redlion Data Logging over EIP
Cody Anderson
Nov 2020
Brockway
36
Hello all, I am working on a DA70A flex edge data logger. I am it communicating with a computer on the network. I can ping it and everything looks okay. I have a simple data log setup, and I want to send the CVS files to a folder in the pc. But I cannot find anywhere to set the directory and link it to a folder. Help please!!
What you probably want to use is the Sync Manager, which can periodically send files from the DataStation to an FTP Server. In Crimson, you find it under Communications -> Services in the navigation pane.
To my knowledge the DataStation can't "map a network directory" and save every data log entry to a file there. Your data logs have to be stored in internal memory, USB, or removable media.
There are also ftpputfile() and ftpgetfile() functions in the Red Lion scripting language; they're in Reference Manual.
Hi, I got a question for those who know a bit more about the RedLions than I do. Can you create a Data Log on a Complex Data Tag? I've got a...
4,111
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
171
Can anyone help me getting this comms connection set up? I am using Port 2 on the Versamax ICU200UDR005-DK, set in SNP with port settings Baud...
1,551
Hello! I have been using cr3000 hmi for some time now using the trend viewer for most monitoring applications that require viewing past data...
1,213
Hi, Is there an easy way to zero all the data from a device when the comms fail? We pull data from some BACNet devices into the Redlion and then...
3,068
