Can Protool RT and Softnet S7 live in harmony together ?
JesperMP
Feb 2003
ᚴᚬᛒᛅᚾᚼᚬᚠᚾ
16,344
I am using Protool RT and Simatic Softnet S7 OPC on separate PCs.
I was wondering if the two software packages can operate on the same time on the same PC.
Protool will be using the internal S7 driver (not the OPC driver).
Will that work ?
My aim is to let the PCs be backups for each other.
If the OPC PC goes down it can run from the Protool PC, and vice-versa.
Thanks for that link Paul (y)
It allmost answers my question.
It says that it IS possible.
Only, it is more involved than I hoped for.
I was thinking that I could just start the Protool RT application on the OPC PC, and then they will live happily side by side.
According to the instructions in that link, I have to set up the Protool project in the "station" that I have to create on the OPC PC.
I have a suspicion that it can be a little bit simpler than that:
Maybe I only have to set up a "PC" (in stead of a "Protool RT" project) as an unconfigured connection on the station. And then RT can connect via that.
It will take some experimenting to find out. Only problem is to find the time to do that ( *sigh* ).
I had a feeling that it would only 'almost' answer your question. But at least it showed you that it is possible to have two connections from the same PC.
If you do find an easier way, can you post your results here please, you never know when a bit of info like that will come in handy.
Paul
I am not completely fazed by the many steps I have to go thru according to that instruction. After having grasped how to set up OPC via Simatic Softnet S7 then you will be deterred by NOTHING (well, almost nothing).
I shall try to remember to post my results here. But I can give no firm date when that will be.
Does anyone know where I can download the Simatic ProTool software? Thanks.
1,548
Hello, I am trying to break in into project from 2012 because it may require some modifications. Currently I am in stage of trying to understand...
2,436
Asking for a friend who has a Protool v1.0 project. He needs to migrate it, and for that he needs to first migrate to v2.51 which he does not...
1,174
So I am working on a machine where the PC has died. The PC was running Windows XP, Protool RT, Step7 V5.3, SimoComU and other software. The...
2,486
HI All I am looking for a way to convert a protool project to win cc I have win cc 2008 SP3 and also newer but from reading I need 2008 SP2 or...
2,766
