Convert Protool file
Donnchadh
Jun 2002
Ireland
1,004
HI All
I am looking for a way to convert a protool project to win cc
I have win cc 2008 SP3 and also newer but from reading I need 2008 SP2 or SP1
If anyone has any ideas how I convert this I would be great full
Donnchadh
The migration option from Protool was removed in SP3. You need WinCC flexible 2008 SP2 to convert the Protool project to WinCC flexible 2008 SP2, then you can convert it to SP3. Maybe you need to change the HMI version in between, depending on the version you have.
If you provide the Protool pdb, maybe someone can do the conversion for you. I have SP2 available to do this.
Help with converison
I don't have SP2 ad need a Protool file converted so I can open in SP3. Your help would be greatly appreciated
THanks,
Jim
someone here?
I have the same problem. I need to migrate a project created in protool to win cc, but I only have SP5, if someone could support me to carry out this conversion and then I can open it in my win cc I would greatly appreciate it! Greetings.
someone here?
Hi all, I have one question about Siemens Protool that I'm using in these days. Is possible to convert a project from protool 6.0 to wincc scada...
3,397
Hello everyone, I have just installed the WinCC flexible 2005 together with SP1 and hotfix so I have never used it before. The project that i...
5,812
P
I have to convert a Siemens OP-15 text display configuration (programmed with COMTEXT) into a OP-17 text display (programmed with ProTool). I know...
4,541
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
92
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
306
