convert COMTEXT configuration into PROTOOL
paul lejeune
Guest
P
I have to convert a Siemens OP-15 text display configuration (programmed with COMTEXT) into a OP-17 text display (programmed with ProTool). I know there's a conversion tool available, but I can't find it.
Can anyone help me ? Thanks.
Reply to [email protected]
This sux
I am trying to do an OP5 to OP77B conversion. I have comtext and the program downloaded from Siemens called Konvert. It is under that name on their support website. The Konvert program looks for an .INI file. I have not been able to figure out how to get an .INI from my .O05 OP5 file yet though.
ALoudermilk:
Hi Al.
We also have to convert an OP5-file to a PROTOOL-file. Up to now we didn't do that, because we're still searching for COMTEXT, but the help-file of KONVERT says, how to do it.
First you have to start COMTEXT and open the OP5-project. With COMTEXT you have to "print" this project to a file. This will create an *.ini file. Next Step is to start KONVERT and open this created INI-file. I hope it'll work.
Greetings
ZIMBO
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
94
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
328
Hi all. Me again still learning Rockwell. So I'll be polling an INT data array from a Modbus SE power meter with a L82 (with a Modbus ProSoft in...
56
1,408
Hello, could someone kindly convert the attached RSP files that are currently used for SLC 5 PLC into PDF please
540
I'm trying to convert an RS Logix 500 fille when I open the 500 file and try to "save as" a .slc file, it does not allow it. It says " SLC library...
699
