data transfer between s7 300 and PC
tny
Jun 2005
usa
105
hi,
i want to transfer some data from a s7 300 to a pc.
what is the easiest (and chipest :) ) way for it.
do i have to use siemens a CP card or a aplicom card?
the transfer does not have to be be quick, i just want to transfer some data blocks to a pc one a day. mpi and profibus are rs485 based protocols, is there a way to transfer this datas via a rs232-485 converter?
The easiest way is ethernet, if the cpu is equipped with it. Otherwis you need to connect an rs232/mpi adapter or usb/mpi adapter.
with a usb(or rs232)to mpi converter, i can see the data blocks via simatic manager, but i have to take the blocks via a program i will write and show them as spread sheets. i am recording the tag times of some stations on a production line, and production engineers need this data. so i want to design a user friendly system for them to archive this datas.how can i take this data to my program via usb-mpi converter?
Then you need to use a simatic driver dll, like prodave, MHJ ComDRV, or a freeware libnodave. Or check my product. It does exactly what you need.
Hi, If we have PLCs on different subnets is it possible to do TCP comms data transfer between them? I'm assuming if we use a routing switch and...
821
Hello there, I'm trying to send the state of a single internal bit (B3:3/8) of my main ML1400 PLC to a different ML1400 over Ethernet using the...
1,755
I need to get data from an MTS temposonics multi-magnet transducer to my motion controller. I think the best option, given the communications...
1,830
Hi Guys, I am relatively new with the PLC's and even newer with A-B. I need to establish Ethernet communication between two controllers to...
1,703
Hi all I have a problem with my thesis. I need to transfer data from Matlab to step 7, does anyone have solution for my case ? I use Step 7 with...
5,670
