TouchPanel MT8102iE failed to connect AB PLC5 over EtherNET/IP
jonney
Apr 2012
Malaysia
70
Recently we had a "Made in China"portable line installed Weiview TouchPanel MT8102iE, it has capability to connect CompactLogix and ControlLogix over EtherNET/IP, but it doesn't support PLC5 over EtherNET/IP. For PLC5, it only provide RS232 via CH0 of PLC5. Are there any workarounds to connect/communicate our PLC5 over EtherNET/IP Network?
If I remember correctly, PLC-5's communicate using EtherNet/IP-PCCC, and newer devices use EtherNet/IP-CIP. So, you may need some type of protocol converter, don't know if one exist or not. Later firmware PLC-5's may support CIP, someone more knowledgeable may know..
I used TCPing.exe to ping PLC5 processor, 2222 got response, 44818 failed. Does the ping result mean this 1785-ENET A or PLC-5/L80C15 processor is EtherNET/IP-PCCC only?
Hi - I have a TP700 Comfort where I am trying to find a way to easily retrieve the audit trail data and alarm logs (normally logged to CSV on the...
1,200
si'm looking for a small,inexpensive, touchpanel HMI that can connect to a printer to print simple text reports. The HMI will read data from a...
2,234
We have a new piece of machinery that has a Siemens touch screen on it(this is our only Siemens based equipment). While comprising a spare parts...
1,817
hi friends i am using g306(red lion) touch panel in that i want to show wen range cross the flash alarm on.I create one real tag in that i given...
1,383
1,497
