I think you'd be looking at the SQL Bridge "module" ($1500) and the Allen-Bradley Driver Suite ($300).
SQL Bridge "limited" ($1000) did data logging only (lacked bi-directional and other feature sets). I'm not sure if that is still available - I'd contact Inductive Automation for details. Here's a pricing sheet from their web site:
https://s3.amazonaws.com/files.indu...78/Ignition-HMI-SCADA+Pricing_09-18-15_en.pdf
You can download a fully functional version to evaluate. The software is exactly the same, but it stops every 2 hours, then you have to manually click a button to start it again. I recommend setting up the project and only purchasing the license if it works for you.
They also have free videos that show you how to use the software.
https://inductiveuniversity.com/
Thank you for the responses.
What is the difference between the SQL Bridge Module Standard Edition and the Limited edition? Can I get these "modules" standalone, or do I have to purchase a full HMI package first?
I installed Visual Studio Community 2015 and downloaded the Advanced HMI. I always get a SocketException when I try to run the project, even if I build and run a fresh copy with no drivers set up. I must be missing something.
