RS232 ASCII String - How to put in a register?
donl517
Dec 2005
Michigan
127
I am receiving an ASCII string via RS232; is it possible to send that data to an N7 register directly? (i.e. ASCII String = N7:0,01)
Will a Micrologix 1500 know what to do with this or do I have to handle it another way?
Thanks,
Don
No, usually you will have to read the string from the buffer(ARD,ARL), extract the number which will still be stored as a string(AEX), then convert it to an integer (ACI)
What is sending the string?
It is coming from an SMAC test unit. They can send anything I want; So I can read it into the ST register and do a string compare as well. I was just curious if there was a way to code it to go directly into a register other than the ST register.
Thanks,
Don
Yes & No, They have I/O on the unit but we have used it all. So we are looking at other avenues of sending a ready signal. I think I will program a first pass to clear the ASCII string at startup and then clear it again at cycle start. That should get me what I need.
Thanks,
Don
Don,
There is an ASCII to PLC Gateway from Real Time Automation that works great. It will take your string data and send it right to a string register in your Micrologix. The part is 435NBS. They have din rail or panel mounting. Very little logic is needed.
http://www.rtaautomation.com/ethernetip/435nba/
They show the 435NBA for the Contrologix family. They only difference really is that the 435NBA sends data to a tag and the 435NBS will be sending to a register.
Rick
ASCII to Allen Bradley
I have several customers who have successfully implemented our DeviceMaster UP products to assist with getting this ASCII data into Micrologix PLCs via Ethernet/IP. Feel free to contact me directly, and I would be happy to extend the invitation to evaluate free of charge.
Does any one knows if micrologix 1100 would be a good choice to receive ascii string characters by Ethernet port and forward it using rs232 port...
5,495
Hi to everybody. I need to read the first 12 characters of the message that a barcode reader sends to the ascii card (1734-rs232 ascii) and I...
725
Hello, I have a linear actuator set up (2 Ewellix linear actuators with hall effect sensor encoders) and an SCU control unit with RS232...
2,115
Hi, I'm new into AB controllers and I'm trying to find how to handle rs232 communication on slc 05/4. I know that I need to configure channel 0...
3,092
Hi, Guys I'm trying to upgrade a device witch comms is thru a RS232. The PLC is a Compactlogix L16ER to a remote PIO 1734-AENT then on this PIO a...
22
8,231
