ACS880 to CompactLogix 5380, Eth I/P, Real values... INT communication.
AutomationTechBrian
Jul 2013
St. Cloud, MN
669
Seems like a simple function, but I don't know how to accomplish it in Studio 5000...
The communication between the ACS880 Eth I/P module and the PLC is with 16 bit integers. I just hit my first REAL value in the drive that I'd like to display on the HMI. I noticed that the value filled 2 fields (communicating to from the VFD to the PLC), as it says it does in the manual. But one thing I haven't done yet is to change those two 16 bit INTs to a real value to display on the HMI.
See the pic....
Any help?
....and while I'm thinking about it, I'll need to input REAL values into the VFD over the same fieldbus communication. How do I take a REAL input from the HMI and convert it to two 16 bit INTs to send correctly to the drive?
You can use COP <SOURCE> <DESTINATION> <LENGTH>
The source is the first INT tag, the destination is the Real tag and the lenght will be 1
Hello all, I have loads of experience using Profibus, Profinet & Modbus TCP, but I have never used EthernetIP. I have a project where I need to...
4,263
Good day everyone. I have an ABB ACS880 VFD that I would like to run in frequency mode. It runs, however instead of the actual output going to...
1,708
Ok heres what Ive got I set the accel time for 300 seconds I selected option accel/deccel 1 I have torque control set to DTC with a minimum...
2,270
Heres my question guys I have the quick start guide, but when I look at the display for my acceleration time parameter, I have four zeros to the...
1,244
I have an application where I have to roughly track the position of a rotary load connected through a reducer to an AC motor. The motor is...
2,329
