![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
Cheap PLC that can read Data from its SD card or USB Flash Drive?
I'm looking for something in the price range of a Productivity 1000 ($180 for CPU, $50 a piece of IO modules). We only need about 8 DI and 8 DO We are looking for a PLC that provides some way for users to set parameters on the PLC without using a separate HMI, without creating our own software, and without having them us the programming software. The problem with the Productivity PLC is, it doesn't support reading from the SD card only writing to it. We would like to be able to read values from a .CSV file on the card. Another option is a PLC that has the ability to let you create your own web pages (with an API to write data) or web-based HMI. Does anything like this exist in this price range? |
#2 |
*bump*
#3 |
![]() ![]() Join Date: Nov 2006
How many parameters?
__________________
S7-300 to 1500 conversions done - email to s7conversions@hotmail.com |
#4 |
![]() ![]() Join Date: Jun 2008
The cheapset version of M241 has built-in 14 DI and 10 DO, it supports SD card read/write and has embedded web server.
I believe the cost should be around 300 USD. I believe it's the web server is a much more user friendly solution.
__________________
automationofthings.blogspot.com |
#5 |
![]() ![]() Join Date: Jun 2017
I've used Unitronics to read / write from an SD card. It has a pretty straightforward utility.
I believe some of the micro 800 line will read / write from an SD card, but i haven't explored that avenue yet, personally. |
#6 |
![]() ![]() Join Date: Oct 2005
Horner.
Their OCS units R/W to an SD. |
#7 |
Have a look at Chapter 9 of the Allen-Bradley Micro 820 User Manual, for the various functions of the SD Card.
You can use the ConfigMeFirst.txt file to set up the firmware load, program path, and IP addressing options for the controller. And you have a Recipe (RCP) instruction that allows your user program to both read and write tags from the SD card. The basic 2080-LC20-20QWB unit has 12 DC Inputs (4 can be used as analog), 7 DC Outputs, and 1 Analog 0-10 volt output. What you can buy those units for is going to depend on your discount schedule; I think street price is $250 - $280. |
#8 |
#9 | |||
Quote:
Quote:
![]() As for Unitronics we were looking at them for a different need and we couldn't even get their programming software to run. It kept freezing when launched. Hmmm I look at them. Do they have something in this budget range though? Quote:
![]() After I posted this we came accross IDEC Smart relays, they seem to offer what we need, I had no idea they had gotten so feature rich, they are more PLC than most microPLCs now. |
#10 |
SoMachine is good and we haven't faced any problems. The question is whether you can get it for free or not.
Another thing is that if you have max 16 adjustable parameters then it seems to me that it's better to use the built-in web server, a cheap Ubiquity AP and a smartphone as HMI device to adjust the parameters or select recipes. Siemens S7-1200 and Eaton smart relays have web servers as well. You could get Unitronics Jazz series Plc which is really cheap and is equipped with a small 2x20 LCD display that can be used to adjust parameters.
__________________
#11 |
![]() ![]() Join Date: Mar 2012
Not that I'm a big fan but Horner does have HMI/plc combo units with a tiny display and some embedded io and expandable. That or a web server I would do before the CSV files but I guess if you have 8 different "recipies" each with a dedicated card that's labelled and all they have to do is insert it and hit start that's not bad then. And you can adda new card without adding to the place like you would with selector switches and such
__________________
Dan Wiebe ----------------- Automation Manager Phoenix Energy Services |
Bookmarks |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Magelis HMI STO501 Datalogging to USB Flash drive | joseplcnet | LIVE PLC Questions And Answers | 0 | March 8th, 2019 02:49 PM |
Transfer Program from Siemens PLC to SD Card | zacslade | LIVE PLC Questions And Answers | 4 | January 17th, 2017 05:22 AM |
Plc step7 read data from kepware opc | princedx | LIVE PLC Questions And Answers | 2 | December 29th, 2014 07:58 PM |
MPI comunication | Manuel Raposo | LIVE PLC Questions And Answers | 22 | July 16th, 2007 07:24 AM |
Review:Toshiba Drive, Horner PLC, DNET | rsdoran | LIVE PLC Questions And Answers | 1 | December 5th, 2003 07:33 AM |
