Studio 5000 V24 crashes when using Save As and when Exporting routines or programs
kpElec
Oct 2016
Minnesota
23
Hi all,
I recently was upgraded from Win7 machine to a Win10 machine with lots of horsepower.
Last Friday, I tried exporting a routine and when I did, Studio 5000 shutdown with no error. I tried exporting multiple times with the same result. Also, I tried using the Save As to save as a Lk5 and Studio 5000 shuts down. However, I can Save a program.
I uninstalled Studio 5000 v24 and reinstalled it and then restarted my pc. When I try to Save As or Export a routine or program, Studio doesn't shut down anymore but acts like the command wasn't given. I am still able to expand programs and open up routines.
I looked on the RA site at the knowledge base but I couldn't find any help there.
Any help would be greatly appreciated.
Thanks,
Kevin
Yes, I installed Studio 5000 v24.01 with Administrative privleges and I ran the LogixDesigner.Exe as Administrative. I'm thinking Win10 is the problem child, eh?
Yes, I tried Win7 and Win8 and Windows XP (Service Pack 3).
When I try to export, I can see the program is trying to do something because I noticed the application flickers a bit.
I just tried Vista and had the same issue.
You realized that I can run Studio 5000, right? I'm just having issues where the "Save As" doesn't work and that I can't export a program or routine.
Yes, saving on my C: drive and I am an administrator on my pc. I can save to the folder as I can see the date updating but the "Save As" doesn't work.
I finally gave up and talked RA. I was using V24.01 which doesn't work on a Win10 machine. They have a version 24.02 that takes care of the problem.
I uninstalled v24.01 and installed v24.02.
Thanks for your help though.
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
112
Hi everyone. I am using a CompactLogix 1769-L24ER with Studio 5000 V24 to control a small machine. Part of the project requires me to communicate...
6,993
I just updated our Studio 5000 Version to v24 but all my program files are v21. How can I update my program files to v24 if I need to? I realize...
11,131
Hello I just installed Studio 5000 onto my computer and after a short bit of time (1-2 min) with the program open I get the following error...
16,023
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
170
