Studio 5000 V24 compatibility with 1769-L35E
jdbjdb
Aug 2011
London
Hi everyone.
I am using a CompactLogix 1769-L24ER with Studio 5000 V24 to control a small machine. Part of the project requires me to communicate with a another machines PLC. This communication will take the form of produced and consumed tags and will be over Ethernet.
My problem is that I have just found out that the other machines PLC is a 1769-35E and this type of controller is not compatible with Studio 5000 V24. Therefore I cannot select this controller in my I/O Configuration.
My question is - What alternatives do I have? Is it possible to use the 2 PLCs mentioned above together? Will one of the application programs have to be re-written (my program is written in Studio 5000 and (I assume) the other PLC will be written in RSLogix 5000)? Is there a comms card that can be added into the network that will allow the L35E to be configured using Studio 5000?
I will be grateful for any input.
I don't think the versions have to match when doing P/C tags. I have a L33 v21 taking to L35 That is at v20 and it works fine.
The Producer/Consumer data exchange functionality, which has been around for many years, is not version dependent.
My training rig has a 1756_L61, and an older 1756_L55. I regularly produce/consume tags between them, even when the L61 is at firmware revision 24 and the L55 is at firmware revision 12.
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
123
Hi all, I recently was upgraded from Win7 machine to a Win10 machine with lots of horsepower. Last Friday, I tried exporting a routine and when I...
4,692
I just updated our Studio 5000 Version to v24 but all my program files are v21. How can I update my program files to v24 if I need to? I realize...
11,140
Hello I just installed Studio 5000 onto my computer and after a short bit of time (1-2 min) with the program open I get the following error...
16,034
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
299
