Torque and Flux Current
bodoo23
Jan 2018
Athens
57
It is said that vector sum of flux and torque current equal to total current drawn by the motor but there are also some currents flowing due to copper losses and rotor leakage inductance. In my opinion, the total current must equal to vector sum of core losses current + torque current and rotor leakage inductance current + flux current ? Is my opinion correct ?
One more question, if we control the motor via contactor , can we say that vector sum of flux and torque current equal to total current drawn by the motor ? I mean if I want to learn how much percent torque I use for a load and I know the flux current of motor which is controlled by contactor. Can I use the formula above to first calculate torque current and then torque percent ?
Thanks in advance.
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
106
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
291
Hello, Would anyone happen to know what parameter in a PowerFlex 525 to have the drive trip if the torque permissive set point is exceeded...
462
Possible dumb question here, but how does running a motor through a gearbox effect a VFDs ability to limit the torque on the driven load? My gut...
542
Hello, I am posting this question (regarding drive control) on this PLC forum because I see that there has been discussion regarding this issue...
627
