TIA POrtal: Copy Array of String to another
janner_10
Dec 2014
Tewkesbury
1,301
I am using v14 with a 1215 dc/dc/dc.
I need to copy a 50 element array of strings to another 50 element array of strings.
I can work it out for the individual elements, but I dont want to this 50 times!
Move_BLK doesn't like strings!
Any suggestions?
EDIT:
Couldn't do it in ladder, this seems to work though!
IF #tempCopy THEN
"Data_TO_Scada".Previous_Pallet_Results_String := "Data_TO_Scada".Live_Results_String;
"Data_TO_Scada".Previous_Pallet_Results_Date_Time := "Data_TO_Scada".Live_Results_Date_Time;
"Data_TO_Scada".Previous_Pallet_ID := "Data_TO_Scada".Current_Pallet_ID;
"Data_TO_Scada".Previous_Number_Reads := "Data_TO_Scada".Current_Number_Reads;
END_IF;
Any suggestions?
Are you trying to move the whole array? If you, you can just use MOVE. When it asks you to enter the element, just use none. Individual elements would be arrayname[XXX], but you can access the whole array with just arrayname.
If you're trying to shift the array (moving 1-20 into 2-21, or whatever) then move_block_variant should work.
Try to organize your data in user defined Data Types, and assign this Data Type to "previous" and "live" structures.
Then you can do in one line:
"Data_TO_Scada".Previous := "Data_TO_Scada".Live ;
Or in Array of Data Type. Then you can do for example
"Data_TO_Scada".Data[0] := "Data_TO_Scada".Data[1] ;
etc.
Hi everyone! I am working on a Siemens plc (1200/1500), and I have two instruction that i have to perform. A) data structure (40 bools, 40...
2,544
All, We are looking into the best ways to protect IP in PLC/SCADA code and the latest offerings included with TIA portal seem much better than...
3,994
Hi all, Straight up question: I'm using TIA Portal and an S7-1200, and wanting to do a straight bitwise copy of all the data in a Word to put it...
16
20,193
Hi! Is it possible to open the project I'm creating on a latest version? I'm working on TIA Portal V19, but the customer needs it on v18.
245
Hi everyone I want to use a vm to run tia portal v13 to v15 What would you suggest, Windows an specification for each portal . Thanks will...
115
