panel view 550 to slc 5/03
how to communicate panel view 550 rs 232 dh 485 protocol to slc 5/03?
rbc,
First choose one, rs232 or dh485.
If you have the 232 on the pv, then I use a 2711-nc13, but I think that its just a straight through 9 pin
If you have "dh 485", check to see if it's DH+485 if it is, then I would use this, its a 3 wire plug conection on the CPU to the PV
Then search Data Highway or DH+ on this site, that sould help, it's easy to set up, give it a try.
Post the exact part number of the Panelview you have and the correct cabling can be selected. The DH485 protocol can (and does) exist on RS232 h/w, the part number will then dictate what cable and/or converter you'll need. The 5/03 doesn't support DH+ so that will introduce another set of issues.
Actually you can have DH485 over RS232 or RS485. It is a very often confused subject
Give us the part number of your Panelview. That is the easiest way to make sure what you need.
On an SLC channel 0 is physically RS232 and channel 1 is physically RS485. Channel 0 is capable of DF1 or DH485. Channel 1 is capable of DH485 only
The following are all DH485 protocol Panelviews. To the right of the part number is the physical port type.
2711-T5A2 RS485
2711-T5A3 RS485
2711-T5A5 RS232
2711-T5A9 RS232
Edit - Well jstolaruk beat me to it but I threw a few part numbers in there too
I don't plan on using any 503's in the future, but what would be the pros or cons to using the 485 protocol over the 232?
Compatibility with other equipment that runs DH485 over RS232. That's the biggest reason I know. Not real sure without knowing the particular application. There is quite a bit of products that run DH485 over RS232.
Just remember there a two parts to the serial. You have the physical and the protocol. Physical would be RS232 and RS485. Protocol would be DF1 and DH485. The fact that they used the 485 number for both the physical and the protocol was a mistake and causes a lot of confusion
I wouldn't do it on a new application but then again I wouldn't do a serial protocol on a new product.
Hello all, I have a Panelview 550 Cat 2711-K5A5 that has one Serial port ( RS-232). Which I can talk to via my cable via DF1. Which is weird...
2,439
Good evening partners, ist my first question on forum, i hope receive any answer. I need make a cable DH485 for communicate an Panel View 550...
2,937
Hello, I have a panel View 550 that went bad , a new one has been installed , when you power up the PV it looks as it did before except there are...
1,791
Panel view CAT number 2711-K5A2 Getting fault "612 No active mode found on network" Not sure if connected correctly and channel configuration is...
2,066
Hi All - I know that this has been covered off previously but I can't find the right solution. I have a: PanelView 550 2711-T5A2L1X 4.41 Connected...
2,785
