Horner PLCs
parkerfw
Jun 2020
Jacksonville, Fl.
We have a lot of the (obsolete) old style horner HE200CCU300C PLCS and would like to replace them. Does anyone know if the programs will work in any other plcs. We would really like not to have to write the programs for all of the new ones.
We are using the cscape 6.50 software.
Fred
Very unlikely, unless they have been written using ST so you could export the source code and it is unlikely that any other manufacturer has a utility to import & convert it. The only hope you have is by upgrading to the Horner new models, even then it may be that a direct conversion cannot be made.
I would just contact Horner technical support, (https://hornerautomation.com/) tell them what you have and let them tell you what their upgrade path is. Find out if you can reuse all or part of your program. If you're satisfied with their answer and the products they offer, you can go with them. If you're not, you can shop around - but it will end up being a re-write if you go with a different vendor.
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
99
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
105
I am having a problem communicating my PLC with Drive via Modbus connection. I start by opening the port and there is no problem, but then when I...
261
Hello, I’m new to this forum and if I’m posting incorrectly let me know. I’ve been having an issue I can’t seem to figure out. I’m sure it’s...
138
I seem to be making this harder than it should be, and Its not making any sense. I simply need to move a real variable to two integer variables...
1,013
