Pto - ab 1400
https://literature.rockwellautomation.com/idc/groups/literature/documents/rm/1763-rm001_-en-p.pdf
"General Information on the PTO
Once running the PTO will continue to generate pulses until all pulses have been generated or the PTO:0/EH (Enable Hard Stop) bit has been activated.
Once the EH bit is set the instruction will generate a PTO error of 1 (hard stop detected). In order to clear this error the PTO instruction must be scanned on a false rung of logic, and the EH bit must be off.
To change the Total Output Pulses Generated in a working program a new value can be moved into PTO:0.TOP by using the MOV command.
Important Note: Once the PTO has been initiated and is generating pulses a new TOP value will not take effect until the PTO has either completed generating pulses and has been restarted or has been Hard Stopped using PTO:0/EH bit and been restarted."
Based on the above, I would say it is not possible. You may want to experiment.
Regards,
Micrologix 1400 PTO function file. I set ADI to “1”. Right clicked ADP, selected “set independent accel/decel value location”, and entered L9:0...
793
Hi, I can't seem to find a thread on this, so I'm starting one. I want to use 2 PTO outputs off a BXB 1400 Micrologix series C. BUT... I need...
1,688
Hello Everyone, I have a new project that I will be working on over the holiday break and have never done a stepper before I am using a...
2,886
Hi all, I have a Micrologix 1400 BWAA and the correct software for it. I would like to learn to program PWM to control a stepper. I am currently...
2,622
Hello, I have a project using 2 stepper motors for X-Y table control, with following items: ML1400 PLC (1766-L32BXB); HMI; 100mm x 100mm lead...
2,018
