WinCC7 change property of multiple controls
gardener
Jun 2008
kiuhkin
Hello,
I have the following question:
on a screen I have some ActiveX controls (piping), I made 2 pipe systems, like Hot and Cold. So I named this controls hotLine1, hotLine2 etc and coldLine1, coldLine2 etc..
Now I would like to change the fillColor of these controls like following (pseudocode):
long int red = 255;
long int blue = 125465;
FOR (all controls in this screen)
IF (control.Name contains "hot") THEN SetFillColor(lpszPictureName,control, red)
ELSE IF (control.Name contains "cold") THEN SetFillColor(lpszPictureName,control, blue)
END IF
can somebody please help me to program this?
ThanK you very much,
Tom
I didn't see yet WINCC 7 but, I guess, in your case there is no diference.
Why do you use two tags for one pipe, and not to use one binnary tag ("0" for "HOT" and "1" for "COLD"). Having this you may open the "Dynamic Dialog" (right click on the property you need -fill colour in your case) and set the colours without writing a script. You althought may get the C script of this property after you have already made the Dynamic Dialog. Right Click on the same property and select "C-Action". A warning message appears, click OK and there it is: the C code of your Dinamic Dialog.
I think it's not clear what I meant:
I dont have one pipe where hot and cold water is flowing through, I have several different pipes, system A = water, system B = steam, system C = NH3. These pipelines I made with several ActiveX controls
now I would like to change the FillColor from only one system, so every control with *steam* in the tagname. Like in the pseudocode written above.
Thanx
i am trying to migrate wincc6.2 project to the new wicc7.2 but i iget error message from CCMigrator “a direct migration wincc 6.2 to wincc 7.2...
1,360
Hi, I want to read conzerv energy meter reading in SCADA. Now i have connected 10 numbers of conzerv energy meters with RS485 and then converted...
1,778
Hi What is mean the access path of tag ? and how i can configure the parameters for every tag? (Adress, tag name, access path) OPC Server...
1,491
Hello forum members, Does anyone have experience they can share of the Siemens WinCC7.3 WebUX product? Many thanks, Nick
1,313
Hi I'm doing a project with wincc7 and s7 300. Now I did a popup page for motors and it is working for every motor. But I want to call every...
1,433
